| Buick God |
May 25, 2006 08:03 AM |
I would start with the fuel system. I've had the sameproblem before and in general, a complete fuel system job will do the trick. Change the fuel filter (should be located driver side rear and is farly easy to replace), add some fuel system cleaning solution (slick 50 gas treatment is the best I found for 3.8L), and it might not hurt to swap out those plugs (and wires depending of the mileage). I recommend the quatro Bosch ones. They're pretty easy to replace, just remember the rear 3 you might have to climb under the vehicle to reach
