Pulls to the right 1993 Roadmaster
Old 11-19-2018, 10:18 AM
Markbrandner's Avatar
Default Pulls to the right 1993 Roadmaster
36,000 mile old man car. Brought to the shop, pulls to the right, replaced couple front end parts,tighten wheel bearings,aligned twice, no change.
Old 11-22-2018, 12:59 PM
If you haven't solved the problem, please post back and maybe we can offer some things to check.
Old 11-22-2018, 01:46 PM
Any help would be appriciated
Old 11-22-2018, 06:05 PM
Are we correct,your vehicle is drifting off to the right when attempting to go straight ahead?
If this is correct, I would suggest checking out the followingl
1. Correct tire pressure according to door sticker on driver's side door
2. Need to know what parts were replaced because,,,,,,,,,,,,,, if vehicle hit something like curb, deep pothole, etc., something could be bent and not noticed during a quick alignment.
3. Rear suspension could be out of line and not checked during alignment.
4. Were rear brakes checked for possible frozen wheel cyl(s) or brake cable not completely releasing causing slight drag resulting in pull to one side?
5. Who was doing the alignment ?
6. Did/do the tires show any unusual signs of wear? Were they rotated to see if any change if switched to rear of vehicle?
Old 11-22-2018, 08:56 PM
Good stuff I will check it out
Old 11-24-2018, 05:40 PM
Went to a different shop, wheel Alignment, still pulled, switched front tires no pull.
moundtown
04-02-2019 04:27 PM
Ed Taublieb
10-09-2017 05:10 PM
fxrider71
04-17-2014 08:12 PM
UCBrave4
08-30-2011 03:56 AM
FJC
07-05-2010 12:09 PM
Quick Reply: Pulls to the right 1993 Roadmaster
