-   -   vibration At 35mph to45mph (https://www.buickforum.com/forum/general-tech-help-13/vibratin-35mph-to45mph-920/)
garllo May 17, 2007 01:05 PM
I have a 2000 Regal LS with 98k mi. It is a great car and I would like to hang on to it . The car has developed one nerve racking trait over the past year. There is a vibration , sort of side to side between 35 and 45mph.After that it smoothens out until 70mph .I do know that it is not tire balancing. It seems to do it in any gear! Any ideas or experience?
Troys 69 GS 400 Jun 6, 2007 07:31 PM
Front end parts are just wearing out. An good alignment shop will help you out.
TrippleT Oct 19, 2008 06:28 PM
your Tires are probably balding on the inside also...
you need ball joints.. lower im guessing.
and NEW TIRES THAT ARE BALANCED
This is a late entry but could help someone else.
garllo Oct 20, 2008 08:06 AM
Actually , as it turned out, the vibration was caused by a worn wheel bearing! I probably should have posted that but I had forgotten about the posting on this forum! Thanks again!
TrippleT Oct 22, 2008 04:27 AM
sweet that helps.
wheel bearings usually make a humming sound.
they dont usually make your car shake...
