i have a 96 buick skylark 3.1 v6. it will start right up but dies
almost instantly. if i keep cranking after it dies for about 10 seconds it will start but the speedometer wont work. after about a minute all the lights on the dash light up and the gauges go to 0. then everything returns to normal but the theft system light stays on. if i shut the car off the process usually starts over. any ideas? Thanks Winston |
check you fuel pressure have you change your fuel filter might be clogged thats why it starts than dies its starving for fuel |
