Hi, I''ve got a 1994 BUICK PARK AVENUE V6-3800 3.8L, and it''s stalling
on me pretty frequently. The car seems to idle and accelerate fine. However, if I use the gas pedal, then once I take my foot off the pedal, the engine stalls. If I let it up slowly and carefully, or if I''m just driving slower, sometimes it won''t stall, but the rpms will drop low and the lights will dim for a second before they go back up. I''ve checked my PCV valve, replaced my spark plugs, and used some wire dryer, fuel line cleaner and gasline antifreeze. At this point I took it to a mechanic. They cleaned the throttle body and mass air flow sensor. Didn''t help, so I brought it back. They replaced the IAC motor. Still didn''t do anything. Any suggestions? Thanks. |
| All times are GMT -5. The time now is 03:44 AM. |
