Greetings
My Park Avenue got one-eyed so I need to replace at least one headlight. Thing is, the sealed beam lights are expensive and hard to come by in my country, so I wonder if there are perchance any replacements to be found that use Halogen H4 or H7 lamps instead? |
GO to junkyarddog.com |
Hello liddy!
I eventually found out that my PA doesn''t use sealed beam lamps at all, it uses pretty standard halogens. So I found new at the nearest gas station. It is a long story why I was mistaken about the lamp type, suffice to say that you should not listen too much to "experts" but rather see for yourself... Thanks anyway, I shall most certainly look up that source you mentioned for other parts. Friendly yours, /Michail |
| All times are GMT -5. The time now is 07:36 AM. |
