92CIVEG |
03-01-2009 03:44 PM |
hello folks i have a 2005 buick rendezvous awd, my transmission went out so i replaced it with a junkyead "rebuild" transmission and transfercase. After getting everything back together the car runs fine the trans is quiet but i have no foward or reverse gears. <BR itxtvisited="1"><BR itxtvisited="1">-the vehicle can roll like its in neutral in PRND21 <BR itxtvisited="1">-there are no stored DTC''S <BR itxtvisited="1">-im getting a command from my scanner that the gear indicated in the cluster is selected. <BR itxtvisited="1"><BR itxtvisited="1">the trans fluid level is perfect, everything mechanically has been bolted up correctly. <BR itxtvisited="1"><BR itxtvisited="1">WHAT AM I MISSING? DID I GET ANOTHER BAD TRANS? <BR itxtvisited="1"><BR itxtvisited="1"><BR itxtvisited="1">THANKS
