-   -   Pulls to the right 1993 Roadmaster (https://www.buickforum.com/forum/general-tech-help-13/pulls-right-1993-roadmaster-8134/)
Markbrandner Nov 19, 2018 10:18 AM
36,000 mile old man car. Brought to the shop, pulls to the right, replaced couple front end parts,tighten wheel bearings,aligned twice, no change.
hanky Nov 22, 2018 12:59 PM
If you haven't solved the problem, please post back and maybe we can offer some things to check.
Markbrandner Nov 22, 2018 01:46 PM
Any help would be appriciated
hanky Nov 22, 2018 06:05 PM
Are we correct,your vehicle is drifting off to the right when attempting to go straight ahead?
If this is correct, I would suggest checking out the followingl
1. Correct tire pressure according to door sticker on driver's side door
2. Need to know what parts were replaced because,,,,,,,,,,,,,, if vehicle hit something like curb, deep pothole, etc., something could be bent and not noticed during a quick alignment.
3. Rear suspension could be out of line and not checked during alignment.
4. Were rear brakes checked for possible frozen wheel cyl(s) or brake cable not completely releasing causing slight drag resulting in pull to one side?
5. Who was doing the alignment ?
6. Did/do the tires show any unusual signs of wear? Were they rotated to see if any change if switched to rear of vehicle?
Markbrandner Nov 22, 2018 08:56 PM
Good stuff I will check it out
Markbrandner Nov 24, 2018 05:40 PM
Went to a different shop, wheel Alignment, still pulled, switched front tires no pull.
