-   -   Programming key fobs (https://www.buickforum.com/forum/general-tech-help-13/programming-key-fobs-265/)
Silver97PA Jan 12, 2006 11:06 PM
I had to purchase 2 new(from Ebay) remotes for my 1997 Park
Avenue. They are the correct remotes for the car. I
received programming instructions with them but in the connector under
the dash, there is no wire in hole #8.(it says to jump pin 4 and pin
8) Were these the correct instructions or is there another way?
Toadster25 Feb 23, 2006 11:36 PM
You do ground pins 4 to 8. Make sure your not looking at it upsidedown.
