A friends car is getting this code when I read the OBD II codes. Its a high MAP pressure. Its sensed by the MAP sensor sending back a slightly high voltage back. Since this is not a P0107 (low MAP pressure (low voltage) I am assuming its not a wiring or connector problem but rather a problem with the MAP sensor. So I am thinking we should replace the MAP sensor.
good thinking ajax your pal, stevie geeeeeeeeeeeeeEdited by: STEVIEG |
