-   -   no heat (https://www.buickforum.com/forum/general-tech-help-13/no-heat-290/)
joeski Feb 4, 2006 01:39 AM
I have a 1980 regal and the heater blows cold. With the engine warmed up and idling the hoses are all pressurized. When I shut the engine off, bubbles flow into the radiator overflow tank. I suspect the thermostat isn't working but don't know for sure. Anyone have a similar situation or ideas?[img]smileys/smiley5.gif[/img]
Erakiel81 Feb 4, 2006 10:24 PM
Maybe your thermostat is stuck open, does the motor take more time than usual to get warm ?
Patrick Feb 9, 2006 01:46 PM
that should be a fairly easy fix...and cheap, if it is the t-stat
