-   -   No A/C on drivers side (https://www.buickforum.com/forum/general-tech-help-13/no-c-drivers-side-6115/)
Happy Ray Feb 22, 2012 09:41 PM
We just purchased an 02 LaSebre Limited and the a/c is cold on the pass side but not the drivers side. A salvage yard is going to paint the front bumper and does repair work also, I've never used them for repair work before, would you use, used parts to repair ?
pafman Feb 22, 2012 09:58 PM
99 time out of 100 the temp door accuator motor is the culprit. they have weak gears inside them and strip out over time. i would recomend NOT using salvage parts for your repair. dorman sells a quality replacement. these also must be calibrated after replacement on your car, so make sure the shop knows what they are doing or the replacement one could be damaged.
