I'm trying to install an aftermarket backup alert system in my 2005
Allure (LaCrosse). The system is supposed to be powered by tapping into the backup light circuit. I'm pretty incompetent when it comes to electrical circuits so I'm having a problem. If I look at the backup light socket, it has two wires running into it...one black, one green. I can't get a 12 volt reading when I connect a multimeter between the two wires when the light is on. What am I doing wrong? Am I using the correct wires? If so, which one is + and which is -? And why don't I get a 12v reading? Any suggestions would be appreciated. Brian |
By trial & error I figured this out....black is ground, LIGHT green is pos.
Brian |
