will the fuel pump on 92 roadmaster 5.7 only run when in tank ?
im not sure exactly what you are asking. do you mean, can you test it when you remove it from the tank? |
yes i want to know if it i can test it before i put it back in the tank etc thanks .roadmaster
yes, just hook up 12 volts to it. just make sure to have a rag near the outlet if theres any fuel in it. but dont run it for more than a second or two. its not good to run them dry. |
thank you have a good day roadmaster
| All times are GMT -5. The time now is 10:10 AM. |
