Hello, 94 Buick Le Sabre V6 engine. It sounds as if afan blade is hitting something, or there are loose pieces of metal in a garbage disposal. Even with Fans stationary. Neutral, Park, Reverse and Forward. The Belt is not touching anything. Even when running for more than a minute. When I took off all spark plug wires and turned the engine over, it never sounded good, a little grinding going on, but the clanking and scraping would sound off in the few seconds after I let go of the key as the engine came to a standstill. It also sounds off after started, as mentioned above. What could this be ? Thank You |
can you take any sort of video?
| All times are GMT -5. The time now is 04:03 AM. |
