-   -   Changing light bulbs behind odometer (https://www.buickforum.com/forum/general-tech-help-13/changing-light-bulbs-behind-odometer-8826/)
MartinBorch Sep 12, 2021 05:02 AM
hi, quick question before I do something wrong.
A couple of the light bulbs are broken. I have tried to see if I can get a hand up behind the entire box holding the speedometer/odometer etc (from below).
Not possible for anyone to get up that way from the floor and up. I have removed the glass cover and as you can see from the picture there are three small nuts holding the front panel. I can see that I also have to disconnect the thin wire which moves the gear indicator.
I am nervous that I by mistake disconnect the speedometer cable if I try to take away the front panel.
- and perhaps these light bulbs can not be removed from inside of the case.
Does anyone know,??
https://cimg6.ibsrv.net/gimg/www.bui...6992d3f55.jpeg
