< src="http://www.google-analytics.com/urchin.js" =text/> </> I have a 97 LeSabre that has a remote start. The vehicle will start via the remote start. It will not start using the key. No sound or the starter trying to engage or anything. All the accessories will work when the key is turned to that position. The remote start has been installed for some time now. The Vats has been disabled/bypassed using a resistor. Whenit is running via the remote start, akey is put in the key cylinder and turned to the on position and then the brake pedal id depressed, the car dies. It is acting as if a key is not present in the cylinder. What could cause this? Is there something in the cylinder to make it known that a key is or isn't there? Please help. < =text/> _uacct = "UA-939292-42"; urchinTracker(); </> |
It sounds like the ignition switch. Just check to see if any buick parts</font> or wiring to the steering column is
disconnected |
| All times are GMT -5. The time now is 03:27 AM. |
