< => <!-- var SymRealOnLoad; var SymReal; Sym() { window.open = SymWinOpen; if(SymReal != null) SymReal(); } SymOnLoad() { if(SymRealOnLoad != null) SymRealOnLoad(); window.open = SymRealWinOpen; SymReal = window.; window. = Sym; } SymRealOnLoad = window.onload; window.onload = SymOnLoad; //--> </> The car ran out of gas and now after putting gas in it , it will not start. Is there a procedure to get gas back to the fuel injection system after it runs out of gas? |
Not aware of any procedure, but you need more than a little gas and often have to crank for quite a while. Also, since the pump is cooled by the gasoline, it sometimes burns outif its been "trying" to pump gas too long. Sorry! |
Originally Posted by MrBSS
Not aware of any procedure, but you need more than a little gas and often have to crank for quite a while. Also, since the pump is cooled by the gasoline, it sometimes burns outif its been "trying" to pump gas too long. Sorry! <!-- var SymRealOnLoad; var SymReal; Sym() { window.open = SymWinOpen; if(SymReal != null) SymReal(); } SymOnLoad() { if(SymRealOnLoad != null) SymRealOnLoad(); window.open = SymRealWinOpen; SymReal = window.; window. = Sym; } SymRealOnLoad = window.onload; window.onload = SymOnLoad; //--> </> |
Thanks a lot for the information. Not aware of any procedure, but you need more than a little gas and often have to crank for quite a while. Also, since the pump is cooled by the gasoline, it sometimes burns outif its been "trying" to pump gas too long. Sorry! <!-- var SymRealOnLoad; var SymReal; Sym() { window.open = SymWinOpen; if(SymReal != null) SymReal(); } SymOnLoad() { if(SymRealOnLoad != null) SymRealOnLoad(); window.open = SymRealWinOpen; SymReal = window.; window. = Sym; } SymRealOnLoad = window.onload; window.onload = SymOnLoad; //--> </> |
| All times are GMT -5. The time now is 02:58 AM. |
