-   -   AC air only comes from defroster. (https://www.buickforum.com/forum/general-tech-help-13/ac-air-nly-comes-defroster-957/)
Marshall Jun 3, 2007 09:13 PM
var SymRealOnLoad;
var SymReal;
Sym()
window.open = SymWinOpen;
if(SymReal != null)
SymReal();
SymOnLoad()
if(SymRealOnLoad != null)
SymRealOnLoad();
window.open = SymRealWinOpen;
SymReal = window.;
window. = Sym;
window.onload = SymOnLoad;
This morning the AC worked normally but this evening, after being parked in the shade all day, it will only pump cold air from the defroster vents and nothing will come from the facia vents. This is a 93 Park Avenue and until today the AC has performed perfectly. Does anyone have an idea about the cause? Obviously there is some sort of directional door that isn't working but what could have caused it so suddenly? Thanks for any input![img]smileys/smiley5.gif[/img]
MrBSS Jun 7, 2007 04:46 PM
Defrost is the default position. This usually indicates a vacuum leak. Edited by: MrBSS
Marshall Jun 7, 2007 08:08 PM
var SymRealOnLoad;
var SymReal;
Sym()
if(SymReal != null)
SymReal();
SymOnLoad()
SymRealOnLoad();
SymReal = window.;
window. = Sym;
Thanks MrBSS. Your post caused me to stop and remember that I had just replaced the spark plugs. I went out and raised the hood and quickly located a vacuum connection that had been disturbed. Problem solved![img]smileys/smiley4.gif[/img]
