-   -   99 Century ABS light on! (https://www.buickforum.com/forum/general-tech-help-13/99-century-abs-light-n-83/)
schellmis Apr 10, 2005 04:36 PM
Hello
Can anyone help me with this one? My car was driving fine. However, the the service engine soon light has always been on. I was thinking because of the Jerking and the wrong spark plugs. I recently had the front brakes done and everything has been going fine. The car drove fine yesterday no diffrent than any other day. I get in the car now and the ABS light is on.. the dash is lit like a Xmas tree and the now the brakes are locked. Car will go into gear but will not move. I am assuming this is a warning of some type or the computer system is jammed. Does anyone have any idea? Turning the car on and off did not help.
Help,, I don't want a tow charge.. Can a system be reset? To see if it is just the computer now updating?
Erakiel81 Apr 10, 2005 05:31 PM
Took a look at the main ground of the car. Often you got two big black
cable on the negative point of the batterie. One goes directly on the
engine and the other goes eleswhere depending on the model of the car.
Also you have a sensor near each disc, it may be unplugged or the cable can be damaged.
