98 Park Ave stalling problem
Old 05-30-2018, 01:06 PM
2Buicks's Avatar
Default 98 Park Ave stalling problem
98 Park Ave. 177000 miles stalls without warning. Then starts sometime later.
Runs fine between stalling incidents. No trouble code registered. "Check Engine" light illuminates when key is turned to "On" prior to startup. Mechanics can't seem to find anything.
Old 06-20-2018, 03:58 PM
I realize this post is a little old, but does the vehicle still have the problem or has it been corrected?
Old 06-21-2018, 04:08 PM
2Buicks's Avatar
It hasn't been fixed yet but it hasn't stalled lately either. So it could at any time. Thanks!
Old 06-22-2018, 02:32 PM
Thanks for the update.
If this should happen when and where you can, dump some cold water on the crank sensor then if the engine starts right up you found the problem.
If you don't feel like waiting for it to happen again, have had more than one crank sensor shut down when it got hot and refused to restart , but started right up after cooling with cold water.
bcdempsey
12-20-2019 10:49 AM
3800forlife
07-19-2012 03:30 PM
dee_dee
02-27-2011 02:59 PM
petey882
11-23-2010 03:38 PM
MrBSS
09-09-2005 02:04 PM
Quick Reply: 98 Park Ave stalling problem
