Trying to determine which relay under hood belongs to fuel pump,no stickers and manuals i have dont show relays..any help greatly appreciated..and believe relay may be getting bad so want to swap with one of the other ones..so if other relay ids are known that will help also.
it is not under the hood. you have to renove the lower kick panel with a torx bit (T15). it is the relay 2nd from the top, on the right side, or more towards the pass. door.
You can open the glove box and move the rubber stops out of the way and drop glove box door down and look inside to the right for the relays
| All times are GMT -5. The time now is 03:22 AM. |
