-   -   93 roadmaster, 5.7L (https://www.buickforum.com/forum/general-tech-help-13/93-roadmaster-5-7l-6355/)
daveeski Sep 16, 2012 05:07 PM
93 roadmaster, 5.7L
been pulling a popup for years. this last time it started to overheat. i turned off ac, turned on heat, and made it 50 miles to campground. i then replaced the t-stat, thought i was good. on way home, it started to overheat again. suggestions?
Merc6 Sep 16, 2012 07:38 PM
Last time radiator cap was checked or replaced?
hanky Sep 18, 2012 04:05 PM
Some things to check out, radiator, water pump ,fan clutch, coolant concentration.
DanielOlaf Oct 7, 2012 10:29 PM
bellad Nov 11, 2012 02:59 AM
i then replaced the t-stat, thought i was good. on way home, it started to overheat again. suggestions?,。。。。。。。
___________________________________________
love me little,love me long!!
http://www.rsdgold.com/
franklin53 Nov 24, 2012 01:31 AM
What does TBI OHV stand for or mean in reference to engines? And SFI DOHC?
What does TBI OHV stand for or mean in reference to engines? And what does SFI DOHC mean. I am talking about two different engines. The TBI OHV is a 93 Buick Roadmaster with a 5.7L V8 and the SFI DOHC is referring to a 2001 Chrysler Sebring Convertable FWD and 2.7L V6.
hanky Nov 24, 2012 11:07 AM
TBI = Throttle body injection - could be one or two fuel injectors
OHV = Overhead valves
SFI = Sequential fuel injection - a fuel injector for each cylinder
DOHC = Dual overhead cams (some engines have only one camshaft to open both intake and exhaust valves, some have two cam shafts one for intake valves and one for exhaust valves and some others have the two camshafts on each bank like in "V" type engine
FWD =Front wheel drive
