92 Skylark shuts off
I have a 92 skylark. But My main problem is while I'm driving my RPM's like to jump all over the place then just shut down. Before it shuts down it hesitates before doing so. A lot has been replaced. Could someone help me know what the problem is?
What has been replaced? That would really help narrow things down.
I'm not really sure i just brought the car with the parts replaced.
I asked the seller what she replaced she said:fuel pump, fuel filter, air filter, thermostat, and vac hoses. They also replaced ignition modual, and that was the first problem they had. Also she's not 100% if they replaced the belt or not.
Well, that narrows it down a lot. It sounds a lot like a vacuum leak. I'd look over all the vacuum hoses, even though they're all new, there could be a kink/bad fitting somewhere. It might also be a good idea to check the fuel lines around the tank..something might have been nipped or kinked when the tank was reinstalled.
ahh Well i'll look at it when i can i'm gonna be busy the nxt two days. Thank you.
Ahh, i forgot 2 mention that it mainly only shuts off when im slowing down or stopped completely. figured that may help out a little more.
That sounds more like a bad fuel pressure regulator. With the car running, or shut off with the key "on," pull the hose on the top of the regulator. If gas drips, or there's a strong smell of gas, the fpr is probably bad.
http://imageshack.us/photo/my-images/638/enginenx.jpg/phttp://img638.imageshack.us/img638/9052/enginenx.jpg
Would you happen to know what is circled in red? |
That looks like the pcv valve. Do you have a clearer picture?
| All times are GMT -5. The time now is 03:00 AM. |
