I have a 92 Park Ave and every once in a while it won't
start. When I turn the key all the lights come on, all electronics work but the engine won't make a noise. Usualy takes anywhere from 5-40 minutes to finaly start up. Any ideas what the problem is?< =""><!-- var SymRealOnLoad; var SymReal; Sym() { window.open = SymWinOpen; if(SymReal != null) SymReal(); } SymOnLoad() { if(SymRealOnLoad != null) SymRealOnLoad(); window.open = SymRealWinOpen; SymReal = window.; window. = Sym; } SymRealOnLoad = window.onload; window.onload = SymOnLoad; //--> </> |
it doesnt make any noise? you say that it takes 5-40 minutes to start...is this 5-40 minutes of cranking? or what is going on during that period?
No the engine makes no noise whatsoever when i turn the key. And in
that 5-40 minutes i'm sitting in my car turning the key every once in a while to see if it'll start. Today i replaced the starter which someone told me wasn't the problem but i didn't have any problems yet so we'll see.< =""><!-- var SymRealOnLoad; var SymReal; Sym() { window.open = SymWinOpen; if(SymReal != null) SymReal(); } SymOnLoad() { if(SymRealOnLoad != null) SymRealOnLoad(); window.open = SymRealWinOpen; SymReal = window.; window. = Sym; } SymRealOnLoad = window.onload; window.onload = SymOnLoad; //--> </> |
It's a possible cause. usually it's the neutral parking switch that is
defective (if you have an auto tranny). The car sometime "think" that you're not on neutral or park and won't start... |
| All times are GMT -5. The time now is 11:44 PM. |
