2004 Buick LeSabre turn signal problem?
I have a weird problem with the right turn signal on my 2004 Buick LeSabre! Some times it works and other times it does not work.
A week or so ago, it started doing this and it has steadily gotten worse. Now it will work once in a while if I can hold the lever in a certain spot. Lights and flasher are all good and all the turn signal lights flash if I put the emergency switch on. Left turn signal works fine. Hoping this isn't something that means steering wheel needs removed to fix! Any help would surly be appreciated. |
If no one here knows what might be wrong, does anyoe know of another forum that I might try? Thanks!
| All times are GMT -5. The time now is 01:42 AM. |
