-   -   2000 Cruise won't stay on Help (https://www.buickforum.com/forum/general-tech-help-13/2000-cruise-wont-stay-help-6349/)
jvm Sep 10, 2012 10:26 AM
My mom's 2000 cruise won't stay on. It will work if I keep the cruise button pressed down on the steering wheel.
It will quit if I let it up.
Anyone Know what to look at? Thanks
Oh it only has 13K on it!!!!!!! She son't get out much
hanky Sep 10, 2012 02:50 PM
Most of the time a relay is used to activate the cruise control. If you have the owner's manual check in the relay section and it will tell you which relay and where it is located.
Sometimes if the stoplite switch is in need of adjustment it will cancel out the cruise control.
Merc6 Sep 16, 2012 03:26 AM
What speeds are we using it at?
jvm Sep 17, 2012 09:55 AM
We were on the freeway doing 70MPH Thanks
jvm Sep 27, 2012 10:31 AM
When I keep the switch pressed down it works, When I let up the cruse dies. Fustrating
hanky Sep 27, 2012 11:29 AM
From all the descriptions you have provided, it sounds like there is a problem with the cruise on/off switch itself. If there was a bad connection or relay problem somewhere the control would not stay working when you keep the button depressed.
