-   -   1996 Buick CV joint replacement (https://www.buickforum.com/forum/general-tech-help-13/1996-buick-cv-joint-replacement-1244/)
kosser70 Nov 10, 2007 01:41 PM
pretty much replaced the whole front end on this car, except the cv joints. i'm out of ideas, redone the whole suspension, replaced factory wheels, new tires, balanced, aligned, new ball joints, tie rods, bearings, calipers, pads.....list goes on and on. only reason why i keep the car is cause it's a tank, and it saved my life, but its becoming a little expensive and irritating. very loud and annoying vibration happens between 35mph and 50mph, then fades off as the speed increases. which manual would you recommend that would be have the simplest instructions, how hard is the job overall, how long should it take.
Thanks
