-   -   1969 Skylark Questions (https://www.buickforum.com/forum/general-tech-help-13/1969-skylark-questions-6312/)
TheGuitarsonist Jul 28, 2012 09:18 PM
Hi, everybody. I have a 69 Skylark. The engine however was replaced with a crate 5.7L: casting number is 14093638.
If I'm in Southern California (warm all year) what's the best oil to use and where can I look to determine what filter to use?
Also, I have a TH350 tranny, any suggestions on fluid?
Novice questions, but I really appreciate the advice. Thanks!
hanky Jul 29, 2012 07:25 PM
There are several different options for what viscosity and type of oil you might use in the engine.
Having had many vehicles with older engines run in higher temps , (fleet) , SAE 15W40 always worked well for me. Newer engines have much closer tolerances and require a much thinner oil like 5W30 and some now even recommend synthetic oil.
Have you tried an auto supply store for the correct oil filter ? Many probably don't go back that far.
If the trans were new or just rebuilt you might have been able to try a synthetic trans fluid, but you might be better off just using Dexron III ATF which is backwards compatible and should be OK.
