-   -   04 Rendezvous cuts out under most all acceleration. (https://www.buickforum.com/forum/general-tech-help-13/04-rendezvous-cuts-out-under-most-all-acceleration-7617/)
44special Aug 17, 2016 07:38 PM
Hi all,
Trying to help my son with his rendezvous. It cuts out on acceleration. Every once and a while, it will go back to normal for maybe 30 minutes. Then back to completely cutting out on all but the mildest acceleration. From a stop, it does well until about 15 mph. If we can make it to 60 mph, virtually no acceleration can happen after that. Any throttle will cause the engine to cut out.No code showing.
When it is cutting out, it sounds horribe. But as soon as you release the throttle, it purrs like a kitten.
New muffler, new cat, new oxy sensor, full tune-up. Drained the fuel, ran seafoam for two tanks, new external fuel filter. Been to the mechanic. Fuel pump is good. I asked about the MAF sensor. He said it was good. We're lost. Mechanic couldn't figure it out. No code doesn't help.
Also, this vehicle starts and idles perfectly.
Has anyone had this happen and successfully found their way through it? I can't believe that this has only happened to us.
I'm hoping for some direction. Thank you.
