-   -   Check Engine P0420 (https://www.buickforum.com/forum/engine-internal-16/check-engine-p0420-9466/)
Changer Apr 26, 2024 05:19 PM
Check Engine P0420
I have a 2015 Buick Encore that keeps telling me I have a check engine light for the same code P0420.I have replace all of the following items...intake manifold, pcv, valve cover gasket, both Bank 1 & 2 sensors, the flex pipe and the cat...the light will go away for a day and then if you drove it for and hour the light comes back on...I am beyond frustrated 😠..car runs great to drive crazy with the engine light...HELP!!!
NTX5467 Aug 9, 2024 11:07 AM
P0420 is for "catalyst efficiency". Which means the front and rear oxygen sensors (on the converter!) are indicating the converter is not working as well as it should. The engine-related oxygen sensors keep the engine running as it should.
Replacement cats are not all created equally or work as well as the OEM production cats do. A few times, our dealership customers opted for the "muffler shop" cats, as they were cheaper, but they kept getting the "catalyst efficiency" code after a while, consistently. Then, we'd put a new GM Parts converter on and all was fixed again.
