-   -   87 LeSabre Error Codes???? (https://www.buickforum.com/forum/engine-internal-16/87-lesabre-error-codes-457/)
samahi72 Jul 12, 2006 10:46 PM
I have an 87 LeSabre. Can you pull error codes? I remember
I had a Chev Celebrity and you could jump a couple of terminals to get
the code. Is that true with Buick? Thanks
samueljackson Jul 13, 2006 08:43 AM
yup its the same procedure. im cant remember for sure what 2 pins u jump but i believe ist the a&L.
u prob could call ur local auto parts store and ask them to look in a code book for the correct pins to jump
BuickLover Feb 19, 2007 07:01 AM
Go to a local Buick auto parts dealer, they should be able to help you look for the needed codes.
_______________
Buick Engines - Original engine in Buick Performance Parts Catalog by TA Performance
hellozaizai May 9, 2013 02:59 AM
code table: http://chinasinoy.com/service/diagno...-table-33.html
hanky Aug 14, 2013 02:32 PM
When looking at the DLC plug , it's the two top holes on the right side (passenger side).
You can jump them with a paper clip.
hanky Sep 5, 2013 05:50 PM
See earlier post #6. If you need help ,just ask.
