-   -   1998 3800 Chunky oil wont drain HELP (https://www.buickforum.com/forum/engine-internal-16/1998-3800-chunky-oil-wont-drain-help-6070/)
diskman01 Jan 30, 2012 04:31 PM
Having oil issues on my 98 Lesabre 3800. Started ticking, then the "Check Oil" light came on. Added about 3 quarts of oil to get home from work. Decided to drain the oil and change filter in case something strange is going on and it IS.
The oil is coming out in chunks. Any ideas? Doesn't look contaminated with coolant but it is very chunky. Had the intake gaskets done about 3 years ago.
HELP
altonherry Oct 13, 2012 12:05 AM
Nice post. I like it. Thanks for sharing these information. Keep it up. :) :D
hanky Oct 13, 2012 03:41 AM
What color is the oil that is draining ?
Have you checked the coolant level and have you lost any ?
When you say chunks, what do they feel like and what does each chunk contain aside from oil?
