Encore Grill Replacement Procedure
Good morning, Newbie here to the forum. Gentlemen, I need some info on how to replace the grill on our 2019 encore. It was damaged by a rock from a passing truck. I have a new grill coming from GM but not sure how to remove the bad one and replace it with the new one. If someone can tell me how to remove the bad one, replacing should be just in reverse. Thanks in advance. PJ
Just for the record, I restore antique British sports cars for a hobby, been doing my own maintenance for many years and have a shop and tools for everything, I just know nothing about these new cars! |
Hi Paul,
I can't tell you exactly how to remove the grille on that 2019. With all your experience disassembling vehicles I'm sure you will be able to figure it out. Unfortunately with today's vehicles you have to remove a lot of stuff to get to everything but with your experience you can handle it. The first time always takes a little longer, but after that ,"most times" it usually takes less time and is sometimes easier. |
| All times are GMT -5. The time now is 05:34 AM. |
