-   -   sensor lights (https://www.buickforum.com/forum/electra-park-avenue-25/sensor-lights-118/)
john harker Jun 7, 2005 10:45 PM
Does anybody have experience with the 3.8 engine Low coolant Sensor light coming on, and although the sensor has been replaced twice in a year, the low coolant light still comes on from time to time and there is no problem with the coolant being low.
Patrick Jun 9, 2005 09:41 PM
it sounds like it could be a wiring issue....is it actually ruining the sensors?
MrBSS Jul 11, 2005 02:34 PM
I have the same problem. I believe the sensor is on the front of the radiator just below the radiator cap. Can anyone confirm?
I cleaned and re-connected the plug this morning, with no apparent improvement. Does it take some start-stop cycles to clear the alert?
I guess the next thing is to remove and clean the sensor itself. Does anybody know if this is likely to work or if I should just get a new sensor? How much isthe sensor? That sucks that you've replaced it twice! I don't know exactly how this sensor works, but you've got to wonder if the problem could be elsewhere.Edited by: MrBSS
john harker Jul 11, 2005 07:32 PM
I left the car with the Dealer when I came north for the summer. The last word from them was they would look at the wiring harness as the source of the problem. The car is back in my driveway, and my grandson has driven it. Seems to be cured.
MrBSS Jul 18, 2005 03:11 PM
For those who may be interested, I think I fixed mine Saturday ('97 Ultra). The sensor just snaps into the radiator,held with two plastic clips. It is inside a clear plastic dome, which might imply optical sensing. Anyway, I took off the dome, cleaned it and the internals with contact cleaner, and reassembled it using dielectric grease.
So far, no "low coolant" message.
MrBSS Jul 26, 2005 12:15 PM
Well today I got a low coolant message again. Guess I'll examine the wire harness, and if that appears good, I'll order a new sensor.
MrBSS Oct 19, 2005 12:24 AM
Cleaned the whole system (overflow bottle had terrible "bathtub ring"), replaced all hoses and the low coolant sensor, filled with new Dexcool. So far, so good.
Patrick Oct 20, 2005 03:35 PM
so you think that it may have been due to some dirt in the system?
MrBSS Oct 24, 2005 11:39 AM
Well, I don't really know. When I first cleaned the sensor, it worked for quite a while. I could have cleaned it again when I changed the coolant and hoses, but I didn't want to take the chance that I would again have a problem, so I just replaced it.
Patrick Oct 24, 2005 04:16 PM
oh, i understand
