-   -   help please problems with 1978 buick electra (https://www.buickforum.com/forum/electra-park-avenue-25/help-please-problems-1978-buick-electra-8496/)
canyonx94 May 2, 2020 06:21 PM
https://cimg8.ibsrv.net/gimg/www.bui...debd8391b.jpeg
i have just recently purchased a 1978 buick electra limited 4 door V8 403 6.6 liter that has been sitting for thirty years in a garage. theres some problems but here are the main two. the gas pedal has zero tension. its straight to the ground and i pick it up it just flops back down. someone tried to break into the car but failed and now there is a big hole on the side of the steering column. it cannot be started with a key but by doing something with a screwdriver in the hole. im not sure what or how thats just what the owner did to start it for me. i dont wanna take out the entire steering column assembly i just wanna fix what i can from inside the car. provided is a photo and a video link showing the two issues. hopefully someone can help me with my issues. thanks
video:
https://cimg0.ibsrv.net/gimg/www.bui...4385844d9.jpeg
hanky May 2, 2020 06:57 PM
If you can locate a GM vehicle in a salvage yard with a similar steering column set up , (Buick, Pontiac, Oldsmobile ) that would be the better way to tackle this. You are going to need some special tools to handle the tilt wheel section and it would be a good idea to do some homework on this first. Sorry no shortcuts here.
canyonx94 May 2, 2020 07:01 PM
i have already done that and i do have the tools to do this i just need to know if theres any way to get the housing off or if i have to work and get all the middle parts out to replace the housing and "wire" because i do not know what i am missing that is not making it start.
hanky May 3, 2020 02:47 PM
First, I don't even know if you can purchase the needed parts for that year. Have you checked if they are available for purchase?
Second,,,,,You just need power going to the + side of the coil when the key is on and the starter is operating.
Next , Did you check if you have spark?
I believe the vehicle has a carburetor. Are you sure fuel is getting up to the carb?
These are basic checks, let us know if any are absent.
canyonx94 May 3, 2020 05:15 PM
the car runs beautifully starts right up with the screwdriver jammed in somewhere in that hole with the key in the ignition but i dont wanna do that everytime i wanna start the car so im trying to repair the steering column completely and yes i have another steering column im using for parts for this car. thanks for the information about the power going to the coil ill see what i can do
