Have a questiom
Old 08-08-2011, 05:21 PM
Blacklabel's Avatar
Default Have a questiom
I need to know how to change the side motor mount on a 1994 buick park avenue 3.8 motor.If you guys could walk me though it that would be great.
Old 08-08-2011, 06:43 PM
Which side?
Old 08-08-2011, 06:51 PM
Blacklabel's Avatar
Its on the left side under one of the ac lines.
Old 08-08-2011, 08:58 PM
It would be more helpful if you said , passenger or driver's side.
Old 08-09-2011, 04:44 AM
Blacklabel's Avatar
It is passenger side.
Old 08-09-2011, 08:14 AM
What kind of equipment do you have to work with?
If you place a jack under the engine just so that it contacts the oil pan at the bolted area on the passenger side. You may need to use a block of wood to prevent damage to the oil pan. All you need to do is take the weight off the mount and then you can remove it. It is extremely important to place the lifting device in a good location so you don't cave in the oil pan. When you can see the engine rise a little and you can remove the bolt that goes through the mount, there is no need to go any higher.
Change what you plan to change and assemble in the reverse order. It's that easy.
duggie
01-27-2022 08:31 AM
buick 3800
Audio/Visual Electronics
10-29-2007 12:59 PM
Michail
06-08-2007 02:13 AM
JasonTx
01-02-2007 05:05 PM
warzak
02-26-2006 12:56 AM
Quick Reply: Have a questiom
