2003 Park Ave driver side mirror glass replacement
The drivers side mirror glass has become optically distorted (dimming, heated, turn signal) on my 2003 Park Ave. Is it possible to replace only the glass?
I think the best answer will come from a Buick dealer parts department. If the glass is available separately then there is a good chance it can be replaced separately.
Driver side mirror and sun visor 97 Park Ave
Been searching for the same with no luck yet. No OEM is available that I have found for driver side. Also I need the driver side visor...... good luck with that.
2003 Park Ave Driver Side Mirror Fix
I also spent considerable time attempting to source a replacement heated, dimming, turn signal glass. I finally settled on a adhesive backed replacement glass that allowed the turn signal led's to show. To date after several years of use the mirror is still functioning acceptably although the heated and dimming features are no longer available.
| All times are GMT -5. The time now is 11:16 PM. |
