turn signal/hazard electrical circuit
I have a 03 century. I replaced the relay, flasher, and bulbs and checked fuses. what i find is interesting is there are no fuses marked turn signals which is common. please advise.:confused:
Do you have the owner's manual?
It should answer that question in the "fuses" section. |
1 Attachment(s)
Attachment 64
(click on the thumbnail to make bigger) This is the diagram of the fuse panel on the passenger side. The fuse for the turn signals/park lamps is in the last row, 4th column from the left. |
obd 1 diagram for 94 lesabre
is there a diagram for OBD 1 94 Lesabre where to place paperclip to produce error code. I had a tech find out 1 time. It was the upper RH port with another plug, but I cant remember which hole the other part of the paper clip goes to. Thanks if you have ideas.
| All times are GMT -5. The time now is 01:40 AM. |
