Transmission Shift Linkage
I had to replace a rusted RF brake line and the RF tie rod end. The car sat so long after I put it back together, I forgot to attach the LF tie rod end. I have now since attached the LF tie rod end.
Now the shift linkage seems to be out of adjustment. I cannot start it unless I put it in neutral. The PRNDL indicator doesn't indicate or light up in Park and the wheels turn for what I think is in the Park gear. Did I screw something up the way the transmission shifts? I don't see any loose electrical connections. Is this something that can be adjust at the transmission shift linkage? |
| All times are GMT -5. The time now is 05:48 AM. |
