how in the hell do you get to the thermostat is it inside the hoseing that comes from the top of the radiator or is somewhere else...please reply |
Should be on top of the engine at end of top radiator hose.
The thermostat is under the throttle body on a 3.1 It is kind of hard to get out because the exhaust is in the way of the bolts. You should be able to get to them without taking the exhaust off but it is kind of hard. Just follow the pipe that the upper radiator hose is connected to.Edited by: Toadster25
| All times are GMT -5. The time now is 03:02 AM. |
