95 Century 3.1L brake line routing
Hi. On my 95 Century 3.1 L I have several questions regarding brake lines and routing. First, can anyone tell me (From the master cylinder) which line goes to each brake? Also what size are the lines themselves? Finally, does anyone have any idea where I can purchase pre bent lines? I've looked everywhere with no success. Thanks
http://www.wholesalegmpartsonline.co...134W04-013.JPG This is for a '98 Century, may be same for '95. Yes, can see problem it's a can of worms. |
If rust and corrosion were the problem, there are new coated steel lines (Metric) available to prevent recurrence.. Some are able to be formed as required, however if you need to alter any ends you will need a bubble flare tool to do the job. As far as pre formed Check Rich B's suggestion.
Some NAPA stores sell the coated lines. |
Thanks for the responses.
There is virtually no information that exists regarding brake lines with these cars. I guess I'm going to have to learn the hard way. I'll probably make a YouTube video on it when I do.
