-   -   1992 Buick century hesitation (https://www.buickforum.com/forum/century-22/1992-buick-century-hesitatin-348/)
Mike C. Apr 9, 2006 11:05 PM
Hello, This is in response to the "Hesitation" issues on my '92 3.3 century with sluggish power/hesitation that started at just highway speeds..and now has progressively got worse with no codes and barely drivable @125,000 miles. I changed ICM no help, and the fuel pump as well, with no results, fuel pressure reading @39lbs. book says 25~44. Has anyone changed the cat converter to relieve this problem? If so did this work. Thanks, Mike
var SymRealOnLoad;
var SymReal;
Sym()
window.open = SymWinOpen;
if(SymReal != null)
SymReal();
SymOnLoad()
if(SymRealOnLoad != null)
SymRealOnLoad();
window.open = SymRealWinOpen;
SymReal = window.;
window. = Sym;
window.onload = SymOnLoad;
Poormanq45 Apr 11, 2006 06:31 PM
Try cleaning the MAF sensor.
I have the same year, but haven't had it long(~2 months). SO I'm not sure if this car has one though, but on my '92 Q45 that was the cause of the problem you described.
Toadster25 May 23, 2006 02:02 AM
yep. try cleaning the Mass air flow sensor.
MrBSS May 23, 2006 02:21 PM
Unless this has been done recently, I would replace the spark plug wires.
