-   -   1987 2.5L Ignition Module Pinout (https://www.buickforum.com/forum/century-22/1987-2-5l-ignitin-module-pinout-693/)
Hudini Dec 29, 2006 12:20 PM
Hello Everyone: I am specifically looking for the tach output of the ignition module to make a remote starter work reliably. I have found an '88 pinout but not sure if it is the same as the '87 2.5L duke ignition module. Any help would be appreciated.</font>
</span></font>
Hudini Jan 1, 2007 04:55 PM
Ok, has me stumped too, lol. '88 Fiero diagram shows Pin A as the tach output of the ign module but lists no color. Actual color of Pin A on my ign module is black/white stripe. '88 Fiero C500 block wiring diagram shows connector C3 as tach input and a white wire. Hmmmmm, got to keep looking I guess. Sure was hoping Pontiac and Buick were using the same harness, but maybe not.
bassasasin Feb 3, 2007 06:52 PM
Try the white wire... Spark timing out.. (and divide by 4)..
Purple white is the Distributor reference pulse
Tan black.. ignition mod bypass...
My schematic says ...
Good Luck
