Car radio installation
Hello, I am a new member of the forum.
I bought an autoraido for my BUuick Enclave last week and I had a problem with the connection of the device. When I looked for installation guides, I came across https://www.player-top.fr/content/ca...adio-gps-buick My installation went well by following the instructions. Currently, I am looking for a reversing camera and I wanted to ask your opinion if the connection of this device is difficult because I do not want to galler during the installation. Thank you in advance for your release. |
Ideally you would be able to procure one of the plug and play harness kits for your project(s). Always got a bit complicated when adding the Amplifiers and Graphic Equalizers. Was told you couldn't feed rear speakers with an Amp that was already amplified. Yup, you can but run volumes low. No clipping or signal distortions that way but way booming. What a sound and then Pioneer Tuneup speakers, sounded like a concert hall.... You could try Crutchfield for components not all that readily available or known about also. Forgot, can also get finish trim & dash parts to complete installation for many of the upgrades. https://www.crutchfield.com/S-hXJ5diDErXW/ |
Something to keep in mind,
If your vehicle is 2008 and later those vehicles also used the CAN system and one of the modules in the network was the radio. If not as required all sorts of problem came up. |
Originally Posted by hanky
(Post 16821)
If your vehicle is 2008 and later those vehicles also used the CAN system and one of the modules in the network was the radio. If not as required all sorts of problem came up. think the same .. |
| All times are GMT -5. The time now is 07:24 AM. |
