2006 Rendezvous Manual Lever for seat recline.
Old 11-10-2013, 12:34 PM
William Morton's Avatar
Default 2006 Rendezvous Manual Lever for seat recline.
My 2006 Rendezvous Driver Seat Manual Lever to recline the is broken and it does not feel like it is connected to anything when I pull it. Is this a common problem with the Rendezvous?
The electric seat controls are working correctly only the manual lever that you pull up on is broken.
Old 03-13-2015, 08:49 PM
Ruben Girona's Avatar
Cool Same issue
I was having the same issue but i took mine apart and found that this metal ring with a tooth to grab the bar was turning in the plastic handle. I just drilled a small self tapping screw through the other side of the tooth and vuala keeps the metal from freely moving. (make sure the screw goes through the plastic handle)
02-21-2015 04:53 AM
MrChips
04-06-2011 01:11 PM
rodram
08-16-2009 06:30 PM
btferg
09-05-2008 12:38 PM
torres
07-31-2006 11:59 AM
Quick Reply: 2006 Rendezvous Manual Lever for seat recline.
