PLEASE HELP !!!!!! DIM lights on Odometer / PRND321 Display - 03 Rendezvoux
Old 07-03-2013, 09:42 PM
orale78's Avatar
Default PLEASE HELP !!!!!! DIM lights on Odometer / PRND321 Display - 03 Rendezvoux
Hi all,
First timer here...
The display containing the Odometer / PRND321 has gone Dim, sometimes is half as Dim, and sometimes when I tap on the cluster or there is a bump on the road it changes the light's intensity.
Does anyone have the fix for this?
This is what I have done already:
Removed cluster
Opened up unit - (Replaced stepper motors while I was at it)
Searched for a section with multiple resistors (as stated in other posts)
Attempted to re-solder (fix) the connection of those resistors
Tested the cluster -- Failed (same issue)
Re-soldered another set of resistors
Re-soldered ALL connections for the display (about 15 on bottom and 15 on top -- sorry did not count them)
I continued to check for solutions for Buick Rendezvoux (or any other GMC, chevy, Cadillac, etc) of a similar build and year but I found nothing applicable (older models have a different problem and therefore a different solution - or maybe the same problem but at a different point on the PCB)
ANYONE????
Thank you all !!
Old 07-08-2013, 07:19 AM
JesusLowe's Avatar
Originally Posted by orale78
Hi all,
First timer here...
The display containing the Odometer / PRND321 has gone Dim, sometimes is half as Dim, and sometimes when I tap on the cluster or there is a bump on the road it changes the cheap hid headlight kits intensity.
Removed cluster
ANYONE????
Thank you all !!
Were you able to solve out the problem? I am facing similar one so if you have any good solutions please share.. Thanks in advance
steveinnepa
10-10-2012 03:45 PM
Lord_Bryan
12-22-2011 12:16 PM
jnlb
10-27-2008 01:52 PM
dogthenine
02-20-2007 09:23 PM
Dustydog
01-21-2006 06:07 AM
Quick Reply: PLEASE HELP !!!!!! DIM lights on Odometer / PRND321 Display - 03 Rendezvoux
