front door panel removal
Old 12-22-2010, 12:33 PM
icar237's Avatar
Default front door panel removal
I need to remove the driver side door panel on my 2006 lucerne cxl to work on the speaker and I don't see any screws to remove. please help with instructions. thanks
Old 12-22-2010, 01:09 PM
The following may apply to your vehicle.
Usually parts of the panel are held on by plastic retainers that can be seen if you just pry the panel away from the door slightly. If so, a special forked tool makes this easy and doesn't destroy the panel cardboard type material. There has to be some method to secure the arm rest to the door or you would pull the panel off every time you closed the door. Sometimes there are small plastic plugs popped in place over the holes and these need to be carefully removed with a small pick or screwdriver in order to get access to the securing screws.Not knowing if the vehicle has side airbags if so leave the job to someone more experienced with air bag procedures.
If no side airbags, after you remove the retainers and screws the panel needs to be raised up off the door in order to move it out of the way. Be careful because you have wiring from the electric windows, door locks, electric mirrors and possibly electric seat controls to contend with and depending on what additional accessories you have maybe more.
Old 12-22-2010, 01:41 PM
icar237's Avatar
Thanks, but there are no plastic plugs to remove that's what has me puzzled. Other cars I have owned in the past did have them but none on the Lucerne door.
Old 12-22-2010, 07:17 PM
On some new models the trim slides away from an area to expose the securing screws.
They have become quite clever in concealing many attachments.
Old 09-07-2012, 09:14 AM
mike33's Avatar
Another question, you have a VP which has manual side mirror controls which can been seen, but you also have power controls too? Err, what am I missing here? LOL
Old 12-28-2016, 09:31 AM
Smokeytires's Avatar
Just removed 2008 lucerne started at top by lock and worked my way around with screwdriver popping plastic keepers underneath. Be careful at right upper as it only had one and mine broke. Then you need to left on it. Can see on utube.
kianme
03-01-2014 07:10 AM
BuickBag
07-05-2011 11:31 AM
dtachia
04-21-2011 03:13 PM
dtachia
04-21-2011 03:11 PM
brich
07-08-2008 10:14 AM
Quick Reply: front door panel removal
