How can I test a Crank Sensor?
Re: '95 Buick LeSabre 3.8 Greetings to my Buick colleagues.
I still have that problem with my check engine light being on. As I said in a post a while ago, I had somebody analyze for codes and got three. PO321, 11360 and PO341. There are three areas included: ICM, Cam sensor and Crank sensor. I had the ICM checked out and it is good. I did check the ground and removed and cleaned the connectors and tightened it up good. I replace the Cam sensor since it was a 15 minute job and now I am facing the Crank Sensor. Can anybody tell me how I can check the crank sensor before I tackle that job of removing the pulley, etc. Thanks
chestatee
06-22-2010 04:15 PM
