1998 Buick Lesabre, Horn stuck on. - Buick Forum - Buick Enthusiasts Forums
Reply
Thread Tools Search this Thread
Old 10-20-2006, 04:32 PM
Hello All!
I was rudely awakened last night, the horn on my Lesabre went off all by itself, (the car had been off for 6 hours). I had to disconnect the - terminal on the battery to get it to stop. Has anyone had this happen to them? Question # 2 where can I get an electrical schematic?
Ray
Old 10-22-2006, 07:03 PM
I've isolated the problem to the combination air bag / horn pad in the steering wheel. I disconnected the battery and removed the air bag module. the dealer parts people say that the only parts available are the wire leads to the module. Has anyone successfully repaired the horn switch that is Incorporated into the air bag?
Ray
Old 10-26-2006, 08:55 PM
Wow thats a new one..
beat on it a bit...or alot.
Elsewise.. you may have to buy a Xpensive part..
Good Luck
Old 04-04-2007, 10:51 AM
did you ever fix your horn problem? I drive a 94 Park Ave Ultra and have the same problem. I'll honk my horn and it stays on until I give it a good hit or two. Sometimes even the slightest grazing will set it off as well.
Reply
Thread Thread Starter Forum Replies Last Post
1995 LeSabre no horn Chrome_Rust LeSabre 3 09-30-2009 02:59 AM
Dead cruise control and horn greenfellow Regal (1973-2004) 0 09-13-2008 06:37 PM
91 Regal horn location...HELP rixxx93t Regal (1973-2004) 0 06-16-2007 12:38 PM
Ignition Stuck in on position "common"? Twi_prime General Tech Help 0 07-09-2006 01:43 PM
Key stuck in ignition dwallbaum Regal (1973-2004) 6 05-03-2006 04:08 PM
Tags
1998, 95, 97, airbag, buick, diagram, horn, la, lesabre, located, pad, problem, problems, sabre, stuck, unplug
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
